Enables or disables configured monitoring on a member port of a health check LAG.
port |
Specifies the member port. |
N/A.
This disables/enables monitoring on a particular member port. When monitoring is disabled, the member port is added back to the LAG if it has not already been added. This allows a member port to be added back to LAG even though connectivity to the host is down.
The following command disables port 12:
configure sharing health-check member-port 12 disable tcp-tracking
This command was first available in ExtremeXOS 12.1.3.
